* include/sh4uart.h: move to include/sh/sh4uart.h.
* include/ispsh7750.h: move to include/rtems/score/ispsh7750.h.
* include/iosh7750.h: move include/rtems/score/iosh7750.h.
* include/sh7750_regs.h: move to include/rtems/score/sh7750_regs.h.
* include/rtems/score/ipl.h: move to include/rtems/score/ipl.h.
* include/rtems/score/sh4_regs.h: Reintroduce from Alexandra
Kossovsky's original sources.
* include/Makefile.am: reflect changes above, remove EXTRA_DIST,
require automake 1.5.
* sci/Makefile.am: Disable compilation of console.c.
* sci/sh4uart.c: include <sh/sh4uart.h>, add SH7750_SCSMR_CHK_S,
remove SH4_CPU_HZ_Frequency;
* score/isph7750.c: Remove #if !defined(sh7750), include sh4_regs.h.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
* clock/ckinit.c, delay/delay.c, include/iosh7032.h,
include/ispsh7032.h, include/sci.h, include/sh7_pfc.h,
include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c,
timer/timer.c: Fixed typo.
* clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h,
include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* clock/ckinit.c, include/iosh7750.h, include/ipl.h,
include/ispsh7750.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c,
score/ispsh7750.c, timer/timer.c: Fixed typo.
* configure.in: Remove.
* include/sh4_regs.h: Deleted and contents merged in score/cpu
to avoid dependencies.
* include/Makefile.am: Reflects above.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
include/Makefile.am, include/iosh7750.h, include/ipl.h,
include/ispsh7750.h, include/sh4_regs.h, include/sh4uart.h,
include/sh7750_regs.h, include/.cvsignore, sci/Makefile.am,
sci/console.c, sci/sh4uart.c, sci/.cvsignore, score/Makefile.am,
score/cpu_asm.c, score/ispsh7750.c, score/.cvsignore,
timer/Makefile.am, timer/timer.c, timer/.cvsignore, configure.ac,
.cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* configure.in: AC_PREREQ(2.52), Adapt CONFIG_SUBDIRS to
autoconf-2.52.
* Makefile.am: reformat noinst_HEADERS to work around a bug in
automake-1.4-p5.
* configure.in: autoupdate to autoconf-2.52, apply RTEMS_CPU_SUBDIRS.
* old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay().
Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* shared/include/cpu.h: Renamed delay() to rtems_bsp_delay().
* cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The
bug has been there all the time, but only hits the leon bsp since the
leon cpu has a 5-stage pipeline (erc32 has 4 stages).
* cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* cache/Makefile.am: Use 'CLEANFILES ='.
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Use 'CLEANFILES ='.
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector
number range check and handling of interrupt priority regs to
conform SH2 specs.
* sci/sci_termios.c: New file.
* include/sci_termios.h: New file.
* include/Makefile.am (EXTRA_DIST): Added sci_termios.h.
(include_sh_HEADERS): Added sci_termios.h.
* score/ispsh7045.c (isp): Calling an ISR with immediate argument
casued negative sign extension for vector numbers of 128 and
above. This was fixed.
* sci/sci.c: Cleaned initialization of SCI registers; added
necessary setup for new TERMIOS console cooperation
conform SH2 specs.
* mpc8xx/console-generic/console-generic.c:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* mpc6xx/timer/timer.c: Added include of bsp.h and removed
external declaration of BSP_Convert_decrementer() to
correct unresolved reference to this routine.
* mpc8xx/console-generic/console-generic.c: Bug found by Yacine
<elkolli@crf.canon.fr> where the initialization or irq data structure
was incomplete in case a SMC channel was used first and later a SCC one.
* mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/vectorisrs.c,
r46xx/vectorisrs/vectorisrs.c, tx39/vectorisrs/vectorisrs.c,
tx39/include/tx3904.h: All exceptions were given low numbers and thus
can be now be installed and processed in a uniform manner just like interrupts.
Variances between various MIPS ISA levels are not accounted for at this time.
* mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/maxvectors.c,
r46xx/vectorisrs/Makefile.am, r46xx/vectorisrs/maxvectors.c,
tx39/vectorisrs/Makefile.am, tx39/vectorisrs/maxvectors.c,
shared/interrupts/maxvectors.c, shared/interrupts/Makefile.am: Split the
shared maxvectors.c into a variety of CPU model specific versions to simplify
the build process and reduce depdencies. Deleted shared/interrupts/maxvectors.c
and created various CPU model versions.
* clock/clock.S: Move placement of nop.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h,
shared/interrupts/maxvectors.c: Now works. Significant rework
of exceptions and interrupt vectoring to clean things up.
* shared/interrupts/vectorexceptions.c: Removed.
* shared/interrupts/Makefile.am: Reflects above.
* shared/interrupts/vectorexceptions.c: New file to decode
exception code and vector appropriate NON-interrupt exception.
* shared/interrupts/Makefile.am: Modified to reflect above.
* mongoosev/duart/mg5uart.c (mg5uart_enable_interrupts): Honor
the other bits set in the Peripheral Function Interrupt Mask
Register when modifying those enabled for the DUART.
* mongoosev/include/mongoose-v.h (MONGOOSEV_ATOMIC_MASK,
MONGOOSEV_PFICR, MONGOOSEV_PFIMR, mongoosev_set_in_pficr,
mongoosev_clear_in_pficr, mongoosev_set_in_pfimr,
mongoosev_clear_in_pfimr, MONGOOSEV_UART_ALL_IRQ_BITS): New macros.
Modifications made with Gregory Menke <gregory.menke@gsfc.nasa.gov>
as he debugged this BSP using a logic analyzer. In particular,
there was a mistake where the index not offset of registers was
in the header file and the baud rate calculation was incorrect.
* mpc8xx/vectors/.cvsignore, mpc8xx/vectors/Makefile.am,
mpc8xx/vectors/README, mpc8xx/vectors/align_h.S
mpc8xx/vectors/vectors.S: These files were removed in
support of switching the mpc8xx to the use the "new exception
processing model."
* mpc8xx/exceptions/.cvsignore, mpc8xx/exceptions/Makefile.am,
mpc8xx/exceptions/asm_utils.S, mpc8xx/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.h: New files.
* configure.in, mpc6xx/mmu/bat.h, mpc8xx/Makefile.am,
mpc8xx/console-generic/console-generic.c,
mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
new_exception_processing/cpu.h, shared/include/byteorder.h,
wrapup/Makefile.am: This is conversion of the
mpc8xx CPU to the "new exception processing model."
* Added mongoose-v, mongoose-v/include, and mongoose-v/vectorisrs
directories.
* mongoosev/.cvsignore, mongoosev/Makefile.am, mongoosev/README,
mongoosev/duart/.cvsignore, mongoosev/duart/Makefile.am,
mongoosev/duart/README.mguart, mongoosev/duart/mg5uart.c,
mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c,
mongoosev/include/.cvsignore, mongoosev/include/Makefile.am,
mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/.cvsignore,
mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/vectorisrs.c:
New files.
* Makefile.am, configure.in, shared/interrupts/Makefile.am,
shared/interrupts/maxvectors.c: Added support for mongoosev.
* tx39/vectorisrs/vectorisrs.c: Corrected warning.
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* clock/Makefile.am: Apply *_HEADERS instead of *H_FILES.
* shared/cache/Makefile.am, tx39/include/Makefile.am:
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am:
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am:
Remove H_FILES.
* include/Makefile.am, syscall/Makefile.am, cache/Makefile.am:
* cache/.cvsignore: Add cache.h.
* Makefile.am: Apply include_*HEADERS instead of H_FILES.
* .cvsignore: Add cache.h.
* clock/ckinit.c (Install_clock): Modified MTU timer 0 initialization
to generate an interrupt exactly every 1us
* r46xx/vectorisrs/vectorisrs.c (mips_get_cause): Corrected
constraints from general to register.
* tx39/vectorisrs/vectorisrs.c (mips_get_cause): Corrected
* Added r46xx directory.
* Makefile.am, configure.in: Modified to reflect addition of r46xx.
* shared/interrupts/installisrentries.c: Fixed typo.
* r46xx/.cvsignore, r46xx/Makefile.am,
r46xx/vectorisrs/.cvsignore, r46xx/vectorisrs/Makefile.am,
r46xx/vectorisrs/vectorisrs.c: New files.
* /dev/null moved to libmisc.
* Makefile.am, configure.in: Removed null directory.
* include/Makefile.am: Removed null.h.
* include/null.h, null/.cvsignore, null/Makefile.am, null/close.c,
null/cntrl.c, null/init.c, null/open.c, null/read.c, null/write.c:
Removed.
