Update #3254.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
This is a preparation to remove the Giant lock.
Update #2555.
Avoid _Thread_Dispatch_increment_disable_level() and
_Thread_Dispatch_decrement_disable_level() and thus the Giant
lock.
Update #2555.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
PR 1777/cpukit
* src/lib/libbsp/powerpc/shared/startup/panic.c,
src/lib/libcpu/sh/sh7032/score/cpu_asm.c,
src/lib/libcpu/sh/sh7045/score/cpu_asm.c,
src/lib/libcpu/sh/sh7750/score/cpu_asm.c,
src/lib/libcpu/sh/shgdb/score/cpu_asm.c: Consolidated access to
_Thread_Dispatch_disable_level.
* sh7032/delay/delay.c, sh7032/score/cpu_asm.c,
sh7032/score/ispsh7032.c, sh7045/sci/sci.c,
sh7045/sci/sci_termios.c, sh7045/score/cpu_asm.c,
sh7045/score/ispsh7045.c, sh7750/sci/sh4uart.c,
sh7750/score/cpu_asm.c, sh7750/score/ispsh7750.c,
shgdb/score/cpu_asm.c, shgdb/score/ispshgdb.c:
PR 1599/cpukit
* sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c,
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Rename
_Context_Switch_necessary to _Thread_Dispatch_necessary to more
properly reflect the intent.
PR 1573/cpukit
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Add a per cpu data
structure which contains the information required by RTEMS for each
CPU core. This encapsulates information such as thread executing,
heir, idle and dispatch needed.
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Spacing.
* Makefile.am, configure.ac, sh7032/score/cpu_asm.c,
sh7045/score/cpu_asm.c, sh7750/score/cpu_asm.c: Move duplicated
context switch code to score/cpu and provide an interrupt handling
stub for the GDB SuperH simulator since it does not support
interrupts or devices. This has been used to run tests on the
simulator BSP as SH1, SH2, and SH4.
* shgdb/score/cpu_asm.c, shgdb/score/ispshgdb.c: New files.
PR 1257/bsps
* sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/score/cpu_asm.c,
sh7045/timer/timer.c, sh7750/score/cpu_asm.c, sh7750/timer/timer.c:
Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* sh7032/clock/ckinit.c, sh7032/delay/delay.c,
sh7032/include/ispsh7032.h, sh7032/sci/sci.c,
sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/clock/ckinit.c,
sh7045/include/ispsh7045.h, sh7045/sci/sci.c,
sh7045/timer/timer.c, sh7750/clock/ckinit.c,
sh7750/include/rtems/score/ispsh7750.h, sh7750/include/sh/sh4uart.h,
sh7750/sci/sh4uart.c, sh7750/score/cpu_asm.c,
sh7750/score/ispsh7750.c, sh7750/timer/timer.c: Convert to using c99
fixed size types.
sh7750/score/cpu_asm.c: Use asm constraint "i" instead of "I" to
pass sizeof(Context_Control) to context switch.
* clock/ckinit.c, include/io_types.h, include/iosh7045.h,
include/ispsh7045.h, include/sci.h, include/sci_termios.h,
include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, sci/sci_termios.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: URL for license
changed.
* score/cpu_asm.c: Removed incorrect statement about copyright
assignment.
* score/cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* sci/Makefile.am: Apply 2002-12-14 patch (Apparently dropped by CVS).
* score/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* sh7045/score/ispsh7045.c: Fixed typos.
* sh7045/score/cpu_asm.c: Fixed typo.
* score/cpu_asm.c, score/ispsh7045.c: Removed warnings.
* sci/Makefile.am: Use .$(OBJEXT) instead of .o.
* score/Makefile.am: Use .$(OBJEXT) instead of .o.
* include/ispsh7045.h, score/ispsh7045.c: Account for name change.
* clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h,
include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector
number range check and handling of interrupt priority regs to
conform SH2 specs.
* sci/sci_termios.c: New file.
* include/sci_termios.h: New file.
* include/Makefile.am (EXTRA_DIST): Added sci_termios.h.
(include_sh_HEADERS): Added sci_termios.h.
* score/ispsh7045.c (isp): Calling an ISR with immediate argument
casued negative sign extension for vector numbers of 128 and
above. This was fixed.
* sci/sci.c: Cleaned initialization of SCI registers; added
necessary setup for new TERMIOS console cooperation
* clock/Makefile.am, null/Makefile.am, sci/Makefile.am,
timer/Makefile.am, score/Makefile.am: Include compile.am
are his notes:
installation prefix).
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
