path: root/c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S (follow)
* Remove (Abandoned).Ralf Corsepius2008-02-191-631/+0
* 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-141-0/+1
| | | | * cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>.
* 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-101-22/+0
| | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_POWEROPEN.
* 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-091-1/+1
| | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_GCC27.
* Remove duplicate white lines.Ralf Corsepius2004-04-211-1/+0
* Remove stray white spaces.Ralf Corsepius2004-04-211-2/+2
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-011-1/+1
| | | | * cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | * cpu.c, cpu_asm.S: URL for license changed.
* 2001-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-201-1/+6
| | | | | | | | | | | | | * support/new_exception_processing/Makefile.am, support/old_exception_processing/Makefile.am, support/old_exception_processing/cpu_asm.S, support/old_exception_processing/irq_stub.S: Modified to reflect old versus new exception processing being a per BSP option. * support/new_exception_processing/c_isr.inl, support/new_exception_processing/cpu.h, support/old_exception_processing/c_isr.inl, support/old_exception_processing/cpu.h, support/old_exception_processing/ppc_offs.h: Removed.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-121-1/+0
| | | | | | | | | * mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c, mpc8xx/timer/timer.c, new_exception_processing/cpu.c, new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S, old_exception_processing/cpu.c, old_exception_processing/cpu.h, old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S: Fixed typo.
* 2000-10-18 Sergei Organov <osv@javad.ru>Joel Sherrill2000-10-181-161/+1
| | | | | | | | | | | | | | | * Added full support for MPC505. * mpc505/ictrl: New directory. * configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition. * mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am, mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files. * mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h". * mpc505/vectors/Makefile.am: alignment exception handler now included. * mpc505/vectors/vectors.S: Now use constants for exception numbers. * old_exception_processing/ppc_offs.h: New file. * old_exception_processing/Makefile.am: Account for ppc_offs.h. * old_exception_processing/cpu.h: Make Nest and Disable levels volatile. * old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
* Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>.Joel Sherrill1999-12-021-0/+809
As part of this effort, the mpc750 libcpu code is now shared with the ppc6xx.
