* | Remove (Abandoned). | Ralf Corsepius | 2008-02-19 | 7 | -2055/+0 |
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 1 | -3/+0 |
| | | | | | | | * mpc5xx/console-generic/console-generic.c, mpc8260/timer/timer.c, new-exceptions/cpu.c, old-exceptions/cpu.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | ||||
* | 2007-11-30 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2007-12-01 | 1 | -1/+14 |
| | | | | | | | * new-exceptions/raw_exception.c, new-exceptions/raw_exception.h, old-exception/cpu.c: define bsp_exceptions_in_RAM variable. This is probably only used by the simulator (were else can you install something to ROM ??). | ||||
* | 2007-11-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-11-28 | 1 | -27/+31 |
| | | | | | | | | | | | | | * mpc5xx/clock/clock.c, mpc5xx/timer/timer.c, mpc8260/clock/clock.c, mpc8260/cpm/brg.c, mpc8260/timer/timer.c, mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c, mpc8xx/timer/timer.c, new-exceptions/raw_exception.c, old-exceptions/cpu.c, ppc403/clock/clock.c, ppc403/console/console.c, ppc403/console/console.c.polled, ppc403/console/console405.c, ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c, ppc403/timer/timer.c, ppc403/tty_drv/tty_drv.c: Eliminate PowerPC specific elements from the CPU Table. They have been replaced with variables named bsp_XXX as needed. | ||||
* | additional fixes for the shared exception code | Thomas Doerfler | 2007-07-10 | 1 | -0/+2 |
* | Remove (Merged into ../ChangeLog) | Ralf Corsepius | 2005-11-04 | 1 | -192/+0 |
* | 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-17 | 1 | -4/+1 |
| | | | | | | | * new-exceptions/cpu.c, rtems/powerpc/powerpc.h: Remove CPU_MINIMUM_STACK_FRAME_SIZE. Use PPC_MINIMUM_STACK_FRAME_SIZE instead. * rtems/powerpc/powerpc.h: Add PPC_MINIMUM_STACK_FRAME_SIZE. | ||||
* | 2005-02-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-15 | 2 | -3/+8 |
| | | | | | * cpu.c: Use _CPU_MSR_GET instead of _CPU_MSR_Value (Unify old/new exception processing API). | ||||
* | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-15 | 2 | -18/+5 |
| | | | | * cpu.c (ppc_exception_vector_addr): Merge ppc603 and ppc603e cases. | ||||
* | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-14 | 4 | -0/+7 |
| | | | | * cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>. | ||||
* | 2005-02-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-13 | 2 | -0/+6 |
| | | | | * cpu.c: Add _PPC_MSR_DISABLE_MASK. | ||||
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 1 | -0/+4 |
| | | | | * Makefile.am, configure.ac: Remove (Unused). | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 5 | -73/+10 |
| | | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 5 | -15/+9 |
| | | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_GCC27. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 1 | -0/+4 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 1 | -0/+4 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-20 | 2 | -0/+6 |
| | | | | | PR 696/bsps * cpu.c: Include bsp.h. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 3 | -5/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 4 | -52/+52 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -1/+5 |
| | | | | * cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 3 | -38/+42 |
| | | | | * cpu.c, ppccache.c: Convert to using c99 fixed size types. | ||||
* | 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-30 | 1 | -0/+5 |
| | | | | | * configure.ac: Add RTEMS_PROG_CCAS. * Makefile.am: Use automake compilation rules. | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 1 | -0/+4 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 1 | -0/+5 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Reformat for preinstallation dirstamp support. | ||||
| | | | | * Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 1 | -0/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 1 | -0/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 3 | -2/+6 |
| | | | | * cpu.c, cpu_asm.S: URL for license changed. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+4 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -0/+4 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -0/+4 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -0/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -0/+4 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-17 | 1 | -0/+5 |
| | | | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg. * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-09-14 | 2 | -0/+7 |
| | | | | | * cpu.c: Include declaration of variable i in ifdef USE_SPRG to eliminate warning. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -0/+4 |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-21 | 1 | -0/+4 |
| | | | | * Makefile.am: Fix oversights in previous patch. | ||||
* | 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-21 | 1 | -0/+6 |
| | | | | | | * rtems.S: Remove. * Makefile.am: Reflect having removed rtems.S. Use AM_CPPFLAGS instead of INCLUDES (Latest automake standard). | ||||
* | 2002-04-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-05-01 | 2 | -0/+6 |
| | | | | * cpu.c: Include <rtems/powerpc/cache.h>. | ||||
* | 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-18 | 1 | -0/+5 |
| | | | | | * rtems/score/cpu.h: Removed. * Makefile.am: Reflect changes above. | ||||
* | 2001-04-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-03 | 1 | -0/+5 |
| | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/cpu.h: Account for name change. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+7 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. |
