Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This is a cache manager implementation header file.
Update #3254.
Make sure also the size is cache aligned since otherwise we may have
some overlap with the next allocation block. A cache invalidate on this
area would be fatal.
This code was only referenced for r46xx CPU models. There are
no BSPs currently in the tree with this CPU model. The r46xx
was the original target for the MIPS port and it is likely that
the code has not been used on actual hardware in many years.
All MIPS BSPs successfully built after this was removed.
Putting the duart in libcpu was very optimistic and presumptuous.
It has never been used again on another SoC and is BSP specific.
* Makefile.am: Add shared/interrupts/isr_entries.h.
* Makefile.am: Remove bogus CFLAGS_OPTIMIZE_V.
* Makefile.am, configure.ac: Reflect addition of rm52xx, tx49.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* Makefile.am: Distibute mongoosev's READMEs
* preinstall.am: New.
* Makefile.am: Merge in au1x00/Makefile.am, mongoosev/Makefile.am,
r46xx/Makefile.am, shared/Makefile.am.
Include preinstall.am.
* au1x00/Makefile.am, mongoosev/Makefile.am,
r46xx/Makefile.am, shared/Makefile.am: Remove.
* Makefile.am, configure.ac: New CPU.
* shared/interrupts/installisrentries.c,
shared/interrupts/isr_entries.S: Added CPU32 support.
* au1x00/Makefile.am, au1x00/include/au1x00.h,
au1x00/vectorisrs/maxvectors.c, au1x00/vectorisrs/vectorisrs.c: New CPU.
* clock/Makefile.am, timer/Makefile.am: Remove.
* r46xx/Makefile.am: Built timer.rel, clock.rel.
Add PREINSTALL_DIRS.
* Makefile.am: Remove timer, clock.
* tx39/Makefile.am, mongoosev/Makefile.am, shared/Makefile.am:
* configure.ac: Reflect removing clock/Makefile.am,
timer/Makefile.am.
Add subdir-objects to AUTOMAKE_OPTIONS.
* clock/Makefile.am: Convert to using automake compilation rules.
* mongoosev/Makefile.am: Ditto.
* r46xx/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* tx39/Makefile.am: Ditto.
* Makefile.am: Remove conditional subdirs.
* configure.ac: Add subdir-object to AUTOMAKE_OPTIONS.
Require automake-1.8.2. Add AM_PROG_CC_C_O.
* Makefile.am: Reformat.
* clock/Makefile.am: Reformat.
* mongoosev/Makefile.am: Reformat. Use dirstamps for preinstallation.
* shared/cache/Makefile.am: Ditto.
* mongoosev/duart/Makefile.am: Ditto.
* mongoosev/vectorisrs/Makefile.am: Reformat.
* r46xx/vectorisrs/Makefile.am: Reformat.
* shared/Makefile.am: Reformat.
* shared/interrupts/Makefile.am: Reformat.
* timer/Makefile.am: Reformat.
* tx39/vectorisrs/Makefile.am: Reformat.
mongoosev/Makefile.am: Reflect having moved automake.
mongoosev/duart/Makefile.am: Reflect having moved automake.
mongoosev/vectorisrs/Makefile.am: Reflect having moved automake.
r46xx/Makefile.am: Reflect having moved automake.
r46xx/vectorisrs/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/cache/Makefile.am: Reflect having moved automake.
shared/interrupts/Makefile.am: Reflect having moved automake.
tx39/Makefile.am: Reflect having moved automake.
tx39/include/Makefile.am: Reflect having moved automake.
tx39/vectorisrs/Makefile.am: Reflect having moved automake.
* mongoosev/duart/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/interrupts/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Added mongoose-v, mongoose-v/include, and mongoose-v/vectorisrs
directories.
* mongoosev/.cvsignore, mongoosev/Makefile.am, mongoosev/README,
mongoosev/duart/.cvsignore, mongoosev/duart/Makefile.am,
mongoosev/duart/README.mguart, mongoosev/duart/mg5uart.c,
mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c,
mongoosev/include/.cvsignore, mongoosev/include/Makefile.am,
mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/.cvsignore,
mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/vectorisrs.c:
New files.
* Makefile.am, configure.in, shared/interrupts/Makefile.am,
shared/interrupts/maxvectors.c: Added support for mongoosev.
* tx39/vectorisrs/vectorisrs.c: Corrected warning.
* Added r46xx directory.
* Makefile.am, configure.in: Modified to reflect addition of r46xx.
* shared/interrupts/installisrentries.c: Fixed typo.
* r46xx/.cvsignore, r46xx/Makefile.am,
r46xx/vectorisrs/.cvsignore, r46xx/vectorisrs/Makefile.am,
r46xx/vectorisrs/vectorisrs.c: New files.
* shared/.cvsignore, shared/Makefile.am,
shared/cache/.cvsignore, shared/cache/Makefile.am,
shared/cache/cache.c, shared/cache/cache_.h,
shared/interrupts/.cvsignore, shared/interrupts/Makefile.am,
shared/interrupts/isr_entries.S,
shared/interrupts/maxvectors.c, tx39/.cvsignore,
tx39/Makefile.am, tx39/include/.cvsignore,
tx39/include/Makefile.am, tx39/include/tx3904.h: New file.
Moved some pieces of interrupt processing from score/cpu to
libcpu/mips since many interrupt servicing characteristics are
CPU model dependent. This patch addresses the number of interrupt
sources and where the ISR prologues are located. The only way to
currently install the ISR prologues requires that the prologues
be installed into RAM.
Joel Sherrill <joel@OARcorp.com>
* This is a major reworking of the mips64orion port to use
gcc predefines as much as possible and a big push to multilib
the mips port. The mips64orion port was copied/renamed to mips
to be more like other GNU tools. Alan did most of the technical
work of determining how to map old macro names used by the mips64orion
port to standard compiler macro definitions. Joel did the merge
with CVS magic to keep individual file history and did the BSP
modifications. Details follow:
* Makefile.am: Made clock and timer subdirectories conditional.
* configure.in: Ditto.
* clock/clock.S: Switch from using <idtmon.h> to <asm.h>.
* clock/gettime.S: Switch from using <idtmon.h> to <asm.h>.
