Fixes #2515.
* cpu.h: Remove warnings.
* cache.c, cpu.h, cpuModel.h:
* byteorder.h, cpu.h, page.c: Fix typo where license said
found in found in.
* cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c:
URL for license changed.
* cache.c: Include <rtems/score/registers.h> instead of
<libcpu/registers.h>.
* cpu.h: Ditto. Remove parts moved to score/cpu/i386.
* registers.h: Add BIG-FAT warning.
significant things:
and PowerPC
same code base.
warning.
Ian Lance Taylor <ian@airs.com> to note that condition codes
are modified.
patch.
Here is a patch which slightly improves the i386 interrupt handling
macros. These macros were written to use both input and output
parameters, which is not necessary. This patch changes them to use
only an input or output parameter, as appropriate. It also changes
the constraints to permit the interrupt level to be loaded directly in
and out of memory, rather than always requiring a register.
You will find enclosed a patch which contains, for Intel PC386 target :
- an Ethernet driver for DEC21140 device based boards.
- a simple cache management with paging mechanism.
Enabled on the pc386.
of theses targets...
