Update #3254.
* at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, lpc22xx/irq/irq.c,
lpc22xx/irq/irq.h, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
pxa255/irq/irq.c, pxa255/irq/irq.h, s3c24xx/irq/irq.c,
s3c24xx/irq/irq.h: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, pxa255/clock/clock.c,
s3c24xx/clock/clockdrv.c: Include <bsp/irq.h> instead of <irq.h>.
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
s3c24xx/irq/bsp_irq_asm.S, s3c24xx/irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above.
* pxa255/include/pxa255.h: Add constants for LCD, Network, and Timer.
* pxa255/irq/bsp_irq_init.c, pxa255/irq/irq.c,
pxa255/irq/irq.h: Change to dummy_handler().
* Makefile.am, configure.ac, preinstall.am: New Gumstix BSP and PXA255
support.
* pxa255/clock/clock.c, pxa255/ffuart/ffuart.c, pxa255/include/bits.h,
pxa255/include/ffuart.h, pxa255/include/pxa255.h,
pxa255/irq/bsp_irq_asm.S, pxa255/irq/bsp_irq_init.c,
pxa255/irq/irq.c, pxa255/irq/irq.h, pxa255/pmc/pmc.c,
pxa255/timer/timer.c: New files.
