Update #3254.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, lpc22xx/irq/irq.c,
lpc22xx/irq/irq.h, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
pxa255/irq/irq.c, pxa255/irq/irq.h, s3c24xx/irq/irq.c,
s3c24xx/irq/irq.h: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, pxa255/clock/clock.c,
s3c24xx/clock/clockdrv.c: Include <bsp/irq.h> instead of <irq.h>.
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
s3c24xx/irq/bsp_irq_asm.S, s3c24xx/irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above.
* lpc22xx/clock/clockdrv.c, lpc22xx/irq/irq.c, lpc22xx/irq/irq.h: Now
runs in Skyeye.
* lpc22xx/clock/clockdrv.c, lpc22xx/include/lpc22xx.h,
lpc22xx/irq/bsp_irq_asm.S, lpc22xx/irq/bsp_irq_init.c,
lpc22xx/irq/irq.c, lpc22xx/irq/irq.h, lpc22xx/timer/timer.c: Update
BSP to address changes between 4.7 and CVS head as well as to address
comments from Ralf and Joel.
* lpc22xx/irq/bsp_irq_init.c
lpc22xx/irq/irq.c, lpc22xx/irq/irq.h: New (Initial submission).
