Update #3254.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, lpc22xx/irq/irq.c,
lpc22xx/irq/irq.h, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
pxa255/irq/irq.c, pxa255/irq/irq.h, s3c24xx/irq/irq.c,
s3c24xx/irq/irq.h: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, pxa255/clock/clock.c,
s3c24xx/clock/clockdrv.c: Include <bsp/irq.h> instead of <irq.h>.
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
s3c24xx/irq/bsp_irq_asm.S, s3c24xx/irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above.
* at91rm9200/clock/clock.c, at91rm9200/dbgu/dbgu.c,
at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, at91rm9200/include/bits.h,
at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, at91rm9200/pmc/pmc.c,
at91rm9200/timer/timer.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/include/mc9328mxl.h, mc9328mxl/irq/bsp_irq_asm.S,
mc9328mxl/irq/bsp_irq_init.c, mc9328mxl/irq/irq.c,
mc9328mxl/irq/irq.h, mc9328mxl/timer/timer.c,
s3c2400/clock/clockdrv.c, s3c2400/timer/timer.c: Correct license URL
and/or fix mistake in copyright notice. Both of these mistakes appear
to be from code submitted after these changes were made previously.
PR 776/bsps
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/irq.h: Added code to
pass interrupt vector number to ISR on AT91RM9200
* at91rm9200/irq/irq.h, mc9328mxl/irq/irq.h, s3c2400/irq/irq.h:
Modified names and types to match rtems/irq.h. Note: rtems/irq.h
should be included after the addition of a parameter to ISRs.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clock.c,
dbgu/.cvsignore, dbgu/dbgu.c, include/at91rm9200.h,
include/at91rm9200_dbgu.h, include/at91rm9200_emac.h,
include/at91rm9200_gpio.h, include/at91rm9200_mem.h,
include/at91rm9200_pmc.h, include/bits.h, irq/.cvsignore,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
pmc/pmc.c, timer/.cvsignore, timer/timer.c: New files.
