* | build: Remove old build system | Sebastian Huber | 2021-09-21 | 1 | -71/+0 |
| | | | | | Close #3250. Close #4081. | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | bsp/riscv: Remove bogus Automake conditional | Sebastian Huber | 2019-11-14 | 1 | -7/+0 |
| | | | | Update #3785. | ||||
* | riscv: Generate linkcmds.base from the shared linkcmds.base.in | Hesham Almatary | 2019-10-27 | 1 | -1/+1 |
| | | | | | This commit moves the existing linkcmds.base to linkcmds.base.in in order to make it configurable by autotools. | ||||
* | riscv: add freedom E310 Arty A7 bsp | Pragnesh Patel | 2019-10-23 | 1 | -0/+8 |
| | | | | | | | Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board. Update #3785. Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com> | ||||
* | riscv: add griscv bsp | Jiri Gaisler | 2019-01-22 | 1 | -2/+2 |
| | | | | Update #3678. | ||||
* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 1 | -1/+0 |
* | bsp/riscv: Use CPU counter btimer | Sebastian Huber | 2018-07-25 | 1 | -1/+1 |
| | | | | Update #3433. | ||||
* | bsp/riscv: Add basic SMP startup | Sebastian Huber | 2018-07-25 | 1 | -1/+1 |
* | bsps/riscv: Update linker-symbols.h | Sebastian Huber | 2018-07-25 | 1 | -1/+0 |
* | riscv: Rework exception handling | Sebastian Huber | 2018-07-25 | 1 | -1/+1 |
| | | | | | | | | | | | Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector() functions. Applications can install an exception handler via the fatal error handler to handle synchronous exceptions. Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must be provided by the BSP. Update #3433. | ||||
* | bsp/riscv: Add device tree support for console | Sebastian Huber | 2018-06-28 | 1 | -5/+4 |
* | bsp/riscv: Add device tree support | Sebastian Huber | 2018-06-28 | 1 | -0/+1 |
* | riscv: Add dummy SMP support | Sebastian Huber | 2018-06-28 | 1 | -0/+3 |
* | bsp/riscv_generic: Rename to "riscv" | Sebastian Huber | 2018-06-27 | 1 | -0/+68 |
Update #3433. |
