* | bsps: Move PCI drivers to bsps | Sebastian Huber | 2018-04-23 | 1 | -100/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | Use fixed-width C99 types for PowerPC in_be16() and co. | Nick Withers | 2014-12-23 | 1 | -5/+7 |
| | | | | | | Also use the const qualifier on the address pointer's target in in_*() Closes #2128 | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -5/+5 |
* | 2009-05-08 Kate Feng <feng1@bnl.gov> | Joel Sherrill | 2009-05-08 | 1 | -93/+32 |
| | | | | | | | | | | | | | | * include/bsp.h, start/start.S, startup/bspstart.c: added CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK in bsp.h. removed BSP_INIT_STACK_SIZE in bsp.h -- it uses __stack defined by the linker script (shared/startup/linkcmds) for the initial stack. replaced __rtems_end+4096 with __stack in start.S Removed legacy code in bspstart.c (inherited from old mvme2307 BSP but not relevant to this one) that tested trapping into PPCBug. Changed ConfVPD_buff[] to be static and added ReadConfVPD_buf() in bspstart.c | ||||
* | Add missing prototypes. | Ralf Corsepius | 2008-08-20 | 1 | -3/+3 |
* | 2007-09-07 Kate Feng <feng1@bnl.gov> | Joel Sherrill | 2007-09-13 | 1 | -43/+26 |
| | | | | | | | | | | | | | | | | * ChangeLog, Makefile.am, README, README.booting, README.irq, preinstall.am, GT64260/MVME5500I2C.c, include/bsp.h, irq/irq.c, irq/irq.h, irq/irq_init.c, pci/detect_host_bridge.c, pci/pci.c, pci/pci_interface.c, pci/pcifinddevice.c, start/preload.S, startup/bspclean.c, startup/bspstart.c, startup/pgtbl_activate.c, startup/reboot.c, vectors/bspException.h, vectors/exceptionhandler.c: Merge my improvements in this BSP including a new network driver for the 1GHz NIC. * network/if_100MHz/GT64260eth.c, network/if_100MHz/GT64260eth.h, network/if_100MHz/GT64260ethreg.h, network/if_100MHz/Makefile.am, network/if_1GHz/Makefile.am, network/if_1GHz/POSSIBLEBUG, network/if_1GHz/if_wm.c, network/if_1GHz/if_wmreg.h, network/if_1GHz/pci_map.c, network/if_1GHz/pcireg.h: New files. | ||||
* | 2005-05-12 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-12 | 1 | -16/+21 |
| | | | | | | | | * README.VME, include/bsp.h, irq/irq.h, network/GT64260eth.c, pci/detect_host_bridge.c, pci/gtpcireg.h, pci/pci.c, pci/pci.h, pci/pci_interface.c, pci/pcifinddevice.c: Submitted by Kate Feng <feng1@bnl.gov> as RTEMS-MVME5500 BSP v1.1 release. Modifications made to merge this release with the current tree. | ||||
* | Add MVME550 BSP | Eric Norum | 2004-10-20 | 1 | -0/+171 |
