Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Also use the const qualifier on the address pointer's target in in_*()
Closes #2128
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
All constants that should have been in cpukit pci.h were moved there.
One naming style was corrected. This impacted if_wm.c.
All other contents were the same as powerpc/shared/pci.h so BSP
specific pci.h could be eliminated.
PR 1786/bsps
* Makefile.am: Add support for Altivec.
* startup/bspstart.c, Makefile.am: Use shared/startup/zerobss.c instead.
* make/custom/mvme5500.cfg: Change CPU_CFLAGS to
"-mcpu=7450 -mtune=7450 -Dmpc7455"
* irq/BSP_irq.c, pci/detect_host_bridge.c, pci.c, pcifinddevice.c:
Remove warnings.
* vme/VMEConfig.h, include/bsp.h: use VME shared IRQ handlers.
* network/if_100MHz/GT64260eth.c: Recycle the Rx mbuf if there
is any Rx error.
PR 1483/cpukit
* pci/pci.c: Rename pci_config into rtems_pci_config_t.
* include/bsp.h, start/start.S, startup/bspstart.c:
added CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK in bsp.h.
removed BSP_INIT_STACK_SIZE in bsp.h -- it uses __stack defined
by the linker script (shared/startup/linkcmds) for the initial
stack.
replaced __rtems_end+4096 with __stack in start.S
Removed legacy code in bspstart.c (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
Changed ConfVPD_buff[] to be static and added ReadConfVPD_buf() in
bspstart.c
* pci/pci.c: Add CVS Id.
* ChangeLog, Makefile.am, README, README.booting, README.irq,
preinstall.am, GT64260/MVME5500I2C.c, include/bsp.h, irq/irq.c,
irq/irq.h, irq/irq_init.c, pci/detect_host_bridge.c, pci/pci.c,
pci/pci_interface.c, pci/pcifinddevice.c, start/preload.S,
startup/bspclean.c, startup/bspstart.c, startup/pgtbl_activate.c,
startup/reboot.c, vectors/bspException.h, vectors/exceptionhandler.c:
Merge my improvements in this BSP including a new network
driver for the 1GHz NIC.
* network/if_100MHz/GT64260eth.c, network/if_100MHz/GT64260eth.h,
network/if_100MHz/GT64260ethreg.h, network/if_100MHz/Makefile.am,
network/if_1GHz/Makefile.am, network/if_1GHz/POSSIBLEBUG,
network/if_1GHz/if_wm.c, network/if_1GHz/if_wmreg.h,
network/if_1GHz/pci_map.c, network/if_1GHz/pcireg.h: New files.
PR 1235/bsps
* pci/pci.c: Add conditional declaration of variables used in debug
printk's.
* GT64260/MVME5500I2C.c, pci/pci.c: Eliminate unchar.
* ep1a/vme/vmeconfig.c, mvme5500/pci/pcifinddevice.c,
* mvme5500/startup/pgtbl_activate.c, mvme5500/vectors/bspException.h,
* mvme5500/vectors/exceptionhandler.c, mvme5500/vme/VME.h,
* mvme5500/vme/vmeconfig.c, score603e/vme/vmeconfig.c, shared/pci/pcifinddevice.c,
* shared/startup/pgtbl_activate.c, shared/startup/pgtbl_setup.c,
* shared/startup/probeMemEnd.c, shared/startup/sbrk.c, shared/vme/VME.h,
* shared/vme/VMEConfig.h, shared/vme/vme_universe.c, shared/vme/vmeconfig.c:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* README.VME, include/bsp.h, irq/irq.h, network/GT64260eth.c,
pci/detect_host_bridge.c, pci/gtpcireg.h, pci/pci.c, pci/pci.h,
pci/pci_interface.c, pci/pcifinddevice.c:
Submitted by Kate Feng <feng1@bnl.gov> as RTEMS-MVME5500 BSP v1.1 release.
Modifications made to merge this release with the current tree.
* network/GT64260eth.c: Fixed warning.
* pci/pci.c, pci/pci.h: Modified to depend upon rtems/pci.h
* pci/pci.c, pci/pci.h, startup/bspstart.c: Name change to support
common PCI interface
* GT64260/GT64260TWSI.c, GT64260/GT64260TWSI.h, irq/GT64260Int.c,
network/GT64260eth.c, pci/pci.c, startup/bspclean.c,
startup/reboot.c: Fix warnings.
* pci/pci.h, pci/pcifinddevice.c: Continue PCI API unification. All use
pci_find_device().
* pci/pci.c, pci/pci.h, startup/bspstart.c: Make PCI initialize
function part of the unified PCI API as pci_initialize().
* README, configure.ac, GT64260/Makefile.am, include/bsp.h,
irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_init.c,
network/GT64260ethreg.h, pci/pci.c, startup/bspstart.c: CVS Id string
and license corrected.
* GT64260/Makefile.in, clock/Makefile.in, console/Makefile.in,
include/Makefile.am, include/Makefile.in, irq/Makefile.in,
network/Makefile.in, pci/Makefile.in, start/Makefile.in,
startup/Makefile.in, vectors/Makefile.in, vme/Makefile.in,
wrapup/Makefile.in: Removed.
