* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Cosmetics.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* .cvsignore, Makefile.am, README, bsp_specs, configure.ac, times,
clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/console.c,
console/console.h, include/.cvsignore, include/Makefile.am,
include/bsp.h, start/.cvsignore, start/Makefile.am, start/start.S,
startup/.cvsignore, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/main.c, startup/setvec.c, timer/.cvsignore,
timer/Makefile.am, timer/timer.c, timer/timerisr.c,
wrapup/.cvsignore, wrapup/Makefile.am, ChangeLog: New files added
as part of merge from OpenCores repository.
