or1ksim BSP was initially named after or1ksim simulator, and it was
intented to only run there. But now it can also run on QEMU, jor1k and
real FPGA boards without modifications. It makes more sense to give
it a new generic name like generic_or1k.
This patch avoids unexpected behavior when initializing tick timer registers.
Initializing these registers fires unexpected exceptions and interrupts even
though RTEMS has not enabled interrupts yet. So, a little long interval added
to allow RTEMS to finish the remaining initialization work before running the
application. The tick timer interval is adjusted to reflect an accurate
timing for RTEMS applications.
This BSP is intended to run on or1ksim (the main OpenRISC emulator).
Fixed version according to Joel comments from the mailing list.
