Update #3285.
output.
* timer/timer.c: Include <rtems/btimer.h>.
* startup/bspclean.c, timer/timer.c: Remove warnings.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* clock/ckinit.c, console/console.c, include/bsp.h,
startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size
types.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
timer/timer.c: URL for license changed.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
.s files to .S in conformance with GNU conventaons. This is a
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
(Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and
T.N.I. (Brest, France)
