Update #3285.
Changed console driver to use interrupts instead of polling.
Change to avoid overwriting CPU32Bug interrupt vector when setting up the Sci interrupt handler.
Fixed type for boolean flag in bsp.h.
Changed mrm332.h to use 25Mhz clock.
Fixes to mrm332.cfg to use correct mcpu32 value for RTEMS_CPU_MODEL instead of m68332 which is no longer supported.
Added -mcpu=cpu32 to compiler options.
Removed broken ROM linker script and replaced broken RAM linker script with working ROM linker script.
Removed no longer required file except_vect_332_ROM.S.
Enabled 0xbeefbeef magic string in start.S to allow MRM version of CPU32Bug to auto run RTEMS.
Removed old code from start.S
Changed compiler optimization flag to optimize for size.
* start/start.S: Update for boot_card command line change.
* c/src/lib/libbsp/m68k/mrm332/include/bsp.h,
c/src/lib/libbsp/m68k/mrm332/start/start.S,
c/src/lib/libbsp/m68k/mrm332/startup/start_c.c: Include
<rtems/m68k/sim.h> instead of <sim.h>.
* c/src/lib/libbsp/m68k/mrm332/include/bsp.h: Include
<rtems/m68k/qsm.h> instead of <qsm.h>.
* console/sci.c, console/sci.h,
console/console.c: Added new SCI driver.
* start/start.c: Removed file.
* start/start.S: New file, the asm portion of the updated start code.
* start/configure.am: Added start.S, removed start.c
* startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c.
* startup/configure.am: Added start_c.c to C_FILES.
* include/bsp.h: Added include <rtems/bspIo.h>
