* | bsps: Move benchmark timer to bsps | Sebastian Huber | 2018-04-20 | 1 | -39/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | Use correct prototype of benchmark_timer_read() | Joel Sherrill | 2014-09-16 | 1 | -1/+1 |
| | | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output. | ||||
* | 2011-02-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-09 | 1 | -1/+2 |
| | | | | | * timer/timer.c: Include <rtems/btimer.h>. Fix benchmark_timer_read() definition. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 1 | -0/+40 |
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init, preinstall.am, clock/clock.c, console/console.c, console/debugio.c, include/bsp.h, include/tm27.h, make/custom/mcf5225x.cfg, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5225x.c, startup/linkcmds, timer/timer.c: New files. |
