Close #3250.
Close #4081.
Update #4267.
controller support.
Update #3269.
Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3520.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Make Clock_driver_support_shutdown_hardware() optional. This avoids
the atexit() support on memory constrained targets.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
