* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 1 | -195/+0 |
| | | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | mcf5225x: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 1 | -0/+2 |
| | | | | Updates #3520. | ||||
* | Add RTEMS linker sets | Sebastian Huber | 2015-12-08 | 1 | -0/+2 |
| | | | | Update #2408. | ||||
* | bsps: Fix TLS support in linker command files | Sebastian Huber | 2014-04-22 | 1 | -1/+3 |
| | | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | ||||
* | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 2014-02-04 | 1 | -0/+17 |
* | 2010-05-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-04 | 1 | -1/+1 |
| | | | | | * include/bsp.h: Add BSP_SMALL_MEMORY. * startup/linkcmds: Wildcard on .data so C++ links. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 1 | -0/+174 |
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init, preinstall.am, clock/clock.c, console/console.c, console/debugio.c, include/bsp.h, include/tm27.h, make/custom/mcf5225x.cfg, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5225x.c, startup/linkcmds, timer/timer.c: New files. |
