* | Remove m68k/idp BSP | Joel Sherrill | 2016-01-23 | 1 | -98/+0 |
| | | | | closes #2546. | ||||
* | m68k/idp: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -1/+1 |
* | Use correct prototype of benchmark_timer_read() | Joel Sherrill | 2014-09-16 | 1 | -1/+1 |
| | | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output. | ||||
* | 2011-02-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-09 | 1 | -1/+2 |
| | | | | | * timer/timer.c: Include <rtems/btimer.h>. Fix benchmark_timer_read() definition. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 1 | -1/+1 |
| | | | | * timer/timer.c: Remove warnings. | ||||
| | | | | * console/leds.c, timer/timer.c: Remove warnings. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -1/+1 |
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 1 | -15/+1 |
| | | | | * timer/timer.c: Eliminate uses of old benchmark timer names. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 1 | -3/+3 |
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 1 | -11/+6 |
| | | | | | * timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 1 | -7/+7 |
| | | | | | * timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | Add missing prototypes. | Ralf Corsepius | 2008-08-19 | 1 | -3/+3 |
* | 2008-02-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-02-15 | 1 | -17/+17 |
| | | | | | * clock/ckinit.c, console/duart.c, timer/timer.c: Reflect changes to rtems/motorola/*.h. | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 1 | -1/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -4/+4 |
* | 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-09 | 1 | -1/+1 |
| | | | | | * timer/timer.c: Include <rtems/rtems/motorola/mc68230.h> instead of <motorola/mc68230.h>. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 1 | -3/+3 |
| | | | | | * clock/ckinit.c, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types. | ||||
| | | | | | * clock/ckinit.c, startup/bspstart.c, timer/timer.c, timer/timerisr.S: URL for license changed. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | moved mc68230.h from main include directory to motorola | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -4/+3 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+121 |
