closes #2546.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
These header files were only used by one BSP and they are
hardware dependent. The hardware dependency always made
them bad candidates for where they were in the tree. But
this fixes that.
and clean up
output.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Conflicts:
for details.
* console/mc68ec.c:
* timer/timer.c: Include <rtems/btimer.h>.
* timer/timer.c: Remove warnings.
* console/leds.c, timer/timer.c: Remove warnings.
* make/custom/idp.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/idp.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
