path: root/c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (follow)
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-150/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any users of these boards so we are removing them. * efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am, efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times, efi332/clock/.cvsignore, efi332/clock/Makefile.am, efi332/clock/ckinit.c, efi332/console/.cvsignore, efi332/console/Makefile.am, efi332/console/console.c, efi332/include/.cvsignore, efi332/include/bsp.h, efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68, efi332/misc/interr.c, efi332/spurious/.cvsignore, efi332/spurious/Makefile.am, efi332/spurious/spinit.c, efi332/start/.cvsignore, efi332/start/Makefile.am, efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld, efi332/start/ram_init.sed, efi332/start/start.c, efi332/startup/.cvsignore, efi332/startup/Makefile.am, efi332/startup/bspclean.c, efi332/startup/bspstart.c, efi332/startup/linkcmds, efi332/startup/linkcmds_ROM, efi332/timer/.cvsignore, efi332/timer/Makefile.am, efi332/timer/timer.c, efi332/wrapup/.cvsignore, efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog, efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs, efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore, efi68k/clock/Makefile.am, efi68k/clock/ckinit.c, efi68k/console/.cvsignore, efi68k/console/Makefile.am, efi68k/console/console.c, efi68k/include/.cvsignore, efi68k/include/16550.h, efi68k/include/DP8570A.h, efi68k/include/bsp.h, efi68k/include/efi68k.h, efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am, efi68k/spurious/spinit.c, efi68k/start/.cvsignore, efi68k/start/start.c, efi68k/startup/.cvsignore, efi68k/startup/Makefile.am, efi68k/startup/bspclean.c, efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c, efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds, efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c, efi68k/timer/.cvsignore, efi68k/timer/Makefile.am, efi68k/timer/timer.c, efi68k/wrapup/.cvsignore, efi68k/wrapup/Makefile.am: Removed.
* 2003-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-021-0/+1
| | | | | | | PR 503/bsps * clock/ckinit.c, include/bsp.h, startup/efi68k_tcp.c, timer/timer.c: Do not include DP8570A.h from bsp.h but still install it. This avoids polluting the namespace.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | * clock/ckinit.c, console/console.c, include/16550.h, include/DP8570A.h, include/bsp.h, spurious/spinit.c, startup/bspclean.c, startup/bspstart.c, startup/efi68k_tcp.c, startup/efi68k_wd.c, startup/setvec.c, timer/timer.c: URL for license changed.
* Removed old hack of using Configuration Table entry ticks_per_timesliceJoel Sherrill2000-01-111-15/+8
| | | | | | | being set to 0 to indicate that there should be no Clock Tick. This was used by the Timing Tests to avoid clock tick overhead perturbing execution times. Now the Timing Tests simply leave the Clock Tick Driver out of the Device Driver Table.
* SPARC port passes all testsJoel Sherrill1995-10-301-12/+4
* Actually adding efi bsp's from John Gwynne after forgetting toJoel Sherrill1995-09-201-0/+165
commit them.
