* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 4 | -200/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, acinclude.m4, configure.ac, cvme961/.cvsignore, cvme961/ChangeLog, cvme961/Makefile.am, cvme961/bsp_specs, cvme961/configure.ac, cvme961/times, cvme961/clock/ckinit.c, cvme961/console/console.c, cvme961/include/.cvsignore, cvme961/include/bsp.h, cvme961/include/tm27.h, cvme961/shmsupp/addrconv.c, cvme961/shmsupp/getcfg.c, cvme961/shmsupp/lock.c, cvme961/shmsupp/mpisr.c, cvme961/start/start.S, cvme961/startup/bspclean.c, cvme961/startup/bspstart.c, cvme961/startup/exit.c, cvme961/startup/linkcmds, cvme961/startup/setvec.c, cvme961/timer/timer.c, cvme961/timer/timerisr.S, i960sim/.cvsignore, i960sim/ChangeLog, i960sim/Makefile.am, i960sim/bsp_specs, i960sim/configure.ac, i960sim/clock/clockdrv.c, i960sim/console/console-io.c, i960sim/console/mon-syscalls.S, i960sim/include/.cvsignore, i960sim/include/bsp.h, i960sim/include/tm27.h, i960sim/start/start.c, i960sim/startup/bspstart.c, i960sim/startup/linkcmds, rxgen960/.cvsignore, rxgen960/ChangeLog, rxgen960/Makefile.am, rxgen960/README, rxgen960/bsp_specs, rxgen960/configure.ac, rxgen960/clock/ckinit.c, rxgen960/console/concntl.h, rxgen960/console/console.c, rxgen960/console/serial.c, rxgen960/console/serial.h, rxgen960/include/.cvsignore, rxgen960/include/bsp.h, rxgen960/include/rxgen960_config.h, rxgen960/include/tm27.h, rxgen960/start/rxgen_romld.S, rxgen960/startup/asmfault.S, rxgen960/startup/asmfault.h, rxgen960/startup/asmstub.S, rxgen960/startup/asmstub.h, rxgen960/startup/bspstart.c, rxgen960/startup/cntrltbl.c, rxgen960/startup/cntrltbl.h, rxgen960/startup/dram.ld, rxgen960/startup/exit.c, rxgen960/startup/fault.c, rxgen960/startup/fault.h, rxgen960/startup/faultret.h, rxgen960/startup/flttbl.c, rxgen960/startup/flttbl.h, rxgen960/startup/frmstr.c, rxgen960/startup/frmstr.h, rxgen960/startup/i960.h, rxgen960/startup/ihandler.S, rxgen960/startup/ihandler.h, rxgen960/startup/intrtbl.c, rxgen960/startup/intrtbl.h, rxgen960/startup/kkprintf.c, rxgen960/startup/linkcmds, rxgen960/startup/linkcmds.real, rxgen960/startup/main.h, rxgen960/startup/memchnl.h, rxgen960/startup/nmi.c, rxgen960/startup/nulsystbl.c, rxgen960/startup/pmc901_memmap.h, rxgen960/startup/prcb.c, rxgen960/startup/prcb.h, rxgen960/startup/rom.ld, rxgen960/startup/rom_cntrltbl.c, rxgen960/startup/rom_ibr.c, rxgen960/startup/rom_ibr.h, rxgen960/startup/rom_prcb.c, rxgen960/startup/rommon.h, rxgen960/startup/sctns.c, rxgen960/startup/sctns.h, rxgen960/startup/setvec.c, rxgen960/startup/systbl.c, rxgen960/startup/systbl.h, rxgen960/startup/time.h, rxgen960/timer/timer.c, rxgen960/timer/timerisr.S: Removed. | ||||
* | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 1 | -4/+2 |
| | | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | ||||
* | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-22 | 2 | -17/+34 |
| | | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 1 | -10/+0 |
| | | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 1 | -1/+0 |
| | | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -1/+1 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -32/+32 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 1 | -3/+3 |
| | | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 1 | -2/+2 |
| | | | | | | * clock/ckinit.c, console/concntl.h, console/console.c, include/bsp.h, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-29 | 1 | -25/+0 |
| | | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
| | | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c, startup/exit.c, startup/setvec.c, timer/timer.c, timer/timerisr.S: URL for license changed. | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -1/+1 |
| | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-16 | 1 | -6/+1 |
| | | | | | | | | | * include/zilog/Makefile.am: Remove. * include/motorola/Makefile.am: Remove. * include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5 * Makefile.am: Require automake-1.5. | ||||
* | 2001-10-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-10-12 | 1 | -1/+0 |
| | | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c, startup/exit.c, startup/setvec.c, timer/timer.c, timer/timerisr.S: Fixed typo. | ||||
* | 2001-09-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-09-28 | 1 | -1/+1 |
| | | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay(). | ||||
* | 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-27 | 1 | -2/+2 |
| | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='. | ||||
* | 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-06-08 | 3 | -7/+14 |
| | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h. | ||||
* | 2000-12-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-06 | 1 | -2/+0 |
| | | | | * include/bsp.h: Removed incorrect error case. | ||||
* | Reworked score/cpu/i960 so it can be safely compiled multilib. All | Joel Sherrill | 2000-07-11 | 1 | -0/+1 |
| | | | | | | | routines and structures that require CPU model specific information are now in libcpu. This required significant rework of the score/cpu header files and the creation of multiple header files and subdirectories in libcpu/i960. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -2/+11 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 2000-01-31 | 2 | -55/+25 |
| | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | ||||
* | Patch rtems-rc-20000104-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | that converts the i960 directory to automake. The same kind of libbsp configuration as for the mips64orion, now for the i960. In addition to libbsp configuration this patch also contains two fixes for cvme961.cfg and rxgen960.cfg, which contained non-functional make-exes. (Now both bsps probably have the same issues with linking c++ applications as the gensh2 has, but this is a different open issue not tried to be solved now). The rxgen961 also seems to have problems with its start file, because linking apps fails due to not finding start.o. (Note that libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this issue to you :) | ||||
* | Fixed path to shared/include/coverhd.h. | Joel Sherrill | 2000-01-03 | 1 | -1/+1 |
* | Now use coverhd.h out of the libbsp/shared directory. | Joel Sherrill | 1999-12-21 | 1 | -1/+1 |
* | Now use shared coverhd.h | Joel Sherrill | 1999-12-21 | 1 | -104/+0 |
* | rxgen960 now compiles -- may not link. | Joel Sherrill | 1999-10-27 | 2 | -20/+10 |
* | Added CVS Ids and a basic header. More header cleanup needed. | Joel Sherrill | 1999-10-27 | 1 | -1/+6 |
* | Replaced Makefile.in's with modified copies of cvme961 to get | Joel Sherrill | 1999-10-27 | 1 | -8/+25 |
| | | | | autoconf/automake changes. | ||||
* | The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson | Joel Sherrill | 1999-10-27 | 4 | -0/+335 |
<mark@ramix.com> of RAMIX. |
