line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Fix the interrupt and stop the spurious interrupt from happening.
The fix moves the EOI to C code and cleans that functionality out
of the asm part of the ISR handler.
The code checks the ISR and IRR registers on the enable.
Only ack the master for a slave IRQ if the slave has no other pending
requests.
PR 1925
* shared/irq/irq.h: Changed i386 console to libchip style console and
added support for com3 and com4.
* shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_init.c: Add
initial support for APIC.
* shared/irq/idt.c, shared/irq/irq.c, shared/irq/irq.h,
shared/irq/irq_asm.h: Fix typo where license said found in found in.
* shared/irq/irq-config.h: Removed file.
* shared/irq/irq.h: Moved defines from 'shared/irq/irq-config.h'.
* shared/irq/irq.h, shared/irq/irq.c, shared/irq/irq_init.c: Converted
to use generic interrupt support.
* shared/irq/irq-config.h: New file.
* shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_asm.S: Add shared
interrupt support to i386.
* shared/irq/irq.h: Fix spelling error.
* irq/irq.c, irq/irq.h: Modified to include rtems/irq.h.
* Makefile.am, comm/i386-stub-glue.c, comm/tty_drv.c, comm/uart.c,
irq/idt.c, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: Moved
irq.h and irq_asm.h to bsp subdirectory.
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: Added parameter
to irq handler
* comm/gdb_glue.c, irq/idt.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_asm.h, irq/irq_init.c: URL for license changed.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
inline with the new IRQ structure.
of theses targets...
