Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
When it's a macro, a function declaration causes a compiler error due to the
macro being expanded.
Partial log showing error:
https://gist.github.com/AmaanC/ab3521141479aa6f61ea25f5d74ebb4d
Closes #3331
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Update #2468.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
The global state of enabled and disabled interrupts has to hold
interrupts really disabled by drivers and system. If the state is
combined with interrupts temporarily disabled because they are
processed at given time then it is impossible to maintain state
by interrupt handlers in drivers.
Fix the interrupt and stop the spurious interrupt from happening.
The fix moves the EOI to C code and cleans that functionality out
of the asm part of the ISR handler.
The code checks the ISR and IRR registers on the enable.
Only ack the master for a slave IRQ if the slave has no other pending
requests.
Move the gdb stub from the i386 UART code to use the libchip drivers.
Use any ports discovered during the probes.
Add gdb control to the boot command line.
Change the device naming to the full device path, not a partial path.
For example /dev/com1.
Start to migrate private symbols to bsp/bspimpl.h.
configuration space
This patch fundamentally results from enhancements to the pc386 BSP
to support systems which do **NOT** have the legacy PCI BIOS. The
patch adds support for detecting when legacy PCI BIOS is not
present and then using IO space to access to PCI Configuration Space.
This resulted in dynamically selected between two implementations
of PCI and refactoring out the shared methods.
This patch adds shared implementations of pci_bus_count() and
pci_find_device(). Subsequent patches will remove implementations
of these methods in other BSPs where possible.
This first step eliminates the following as public APIs for the pc386
BSP:
+ pcib_conf_read8
+ pcib_conf_read16
+ pcib_conf_read32
+ pcib_conf_write8
+ pcib_conf_write16
+ pcib_conf_write32
The if_fxp.c driver uses these enough where I provided local macros
to allow the code to be mostly unmodified. On other architectures
these names have been used privately. It will take multiple patches
to completely eliminate these symbols from the RTEMS source tree.
The focus of the first effort is just to eliminate these as a public
pc386 API so support can be added for systems without legacy PCI BIOS.
Update #2554.
Fixes #2515.
The current algorithm scans all PCI busses (0..ff)
and all devices (0..31) on each bus for bridges
and determines the maximum of all subordinate
busses encountered.
However, the algorithm does not scan all functions
present in multi-function devices -- I have a PCI express
root complex (82801H) where multiple (non-zero index)
functions are 'PCI bridges' whose subordinate bus number is
missed by the original algorithm.
This commit makes sure that the scan
is extended to all functions of multi-function
devices.
See #2067
structs, break >80 chars lines, removed newlines at EOFs
fb_vesa_rm.c: removed inline from functions declared in fb_vesa.h
removed unnecessary printks in the end of patch
edid.h, vbe3.h: switched from custom *PACKED_ATTRIBUTE at the structs to the
RTEMS_COMPILER_PACKED_ATTRIBUTE for easier maintainability
of doxygen
BSP_uart_termios_write_com1 and BSP_uart_termios_write_com2
Clustered/partitioned scheduling helps to control the worst-case
latencies in the system. The goal is to reduce the amount of shared
state in the system and thus prevention of lock contention. Modern
multi-processor systems tend to have several layers of data and
instruction caches. With clustered/partitioned scheduling it is
possible to honour the cache topology of a system and thus avoid
expensive cache synchronization traffic.
We have clustered scheduling in case the set of processors of a system
is partitioned into non-empty pairwise-disjoint subsets. These subsets
are called clusters. Clusters with a cardinality of one are partitions.
Each cluster is owned by exactly one scheduler instance.
Add and use _CPU_SMP_Start_processor(). Add and use
_CPU_SMP_Finalize_initialization(). This makes most
_CPU_SMP_Initialize() functions a bit simpler since we can calculate the
minimum value of the count of processors requested by the application
configuration and the count of physically or virtually available
processors in the high-level code.
The CPU port has now the ability to signal a processor start failure.
With the support for clustered/partitioned scheduling the presence of
particular processors can be configured to be optional or mandatory.
There will be a fatal error only in case mandatory processors are not
present.
The CPU port may use a timeout to monitor the start of a processor.
Rename rtems_smp_process_interrupt() into
_SMP_Inter_processor_interrupt_handler(). Delete unused header file
<rtems/bspsmp.h>.
Rename rtems_smp_secondary_cpu_initialize() into
_SMP_Start_multitasking_on_secondary_processor(). Move declaration to
<rtems/score/smpimpl.h>.
