* start/start.S: Update for boot_card command line change.
* timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
start/80386ex.h, start/80386ex.inc, start/macros.inc, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/setvec.c,
timer/timer.c, timer/timerisr.S: URL for license changed.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
converted to automake.
that converts the libbsp/i386 subdirectory to full automake.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
reported bugs in the start code.
to fix problem reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
Date: Fri, 30 Jul 1999 14:53:20 -0500 (CDT)
it is used like this in i386ex/start/start.S
/* set up same values in cache */
start.S: movw $0xFFFB, SYM(i8259s_cache)
I am heading out the door. Any other ideas what could have tripped this?
This instruction appears in a .code16 section. In a .code16 section,
current versions of gas assume that all addresses are 16 bits unless
told otherwise.
If you change the line to
addr32 movw $0xFFFB, SYM(i8259s_cache)
then you will get a 32 bit address reference.
You may want to use addr32 only when NEW_GAS is defined.
dependencies of "Makefile".
--enable-maintainer-mode.
jmp relative offset from .reset section.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
<raguet@crf.canon.fr>.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
test were suggested by Ian Taylor <ian@airs.com> and Joel did the
hard part of putting it in aclocal and editting all the offending
Makefiles and source code which could use this feature.
Please find attached a start.s that includes a cli prior to the hlt
instruction. This ensures that external interrupts cannot restart
the system after returning to the startup code. ( According to the hlt
docs, they will! )
Also find a new timer.c. ( I forgot to update the countdowm value
in the timer when I changed the PSCLK frequency in start.s) . This
improves timer accuracy.
The raw_idt_notify messages are no longer infinite, I tested sp11 and
sp05, both which were bad, and I have seen the message print once in
one test. I think it's ok if it prints out once. In fact, I don't
think you can effectively stop it!
Please find attached the two files that have been changed relative to
980921 . The changes here are in the handling of the counter-timer used
as the basis for the rtems executive clock. For the most part, these
are housekeeping changes.
The PSCLK frequency change in start.s... was a part of several
bug-fixes. The fix improves executive clock and timer accuracy.
changes :
start.s -- All timers are disabled by the initialization routine
-- PSCLK ( used by clock and timers ) frequency changed to 1MHz
The clock_initialize routine now assumes that the PSCLK frequency is
exactly 1 MHz.
ckinit.c
Clock_isr -- removed division by 1000. Now use 'static'
variable -- clock_intial_isr_value -- to reset Clock_isrs variable.
clock_initialize -- moved counter timer initialization here. Values
used to configure the timer are totally dependent on
BSP_configuration.microseconds_per_tick ( and the PSCLK assumption).
Initializes clock_initial_isr_value used by th Clock_isr to reset
Clock_isrs.
clock_on -- no longer configures the timer, just enables it.
Since altering the number of sections in the BSP, I decided to give it a
good "once over" . The clock handling is now cleaner.
i386ex bsp up to date.
1) A 'hlt' instruction is coded in case of a return from boot_card in
start.s.
inline with the new IRQ structure.
Also removed bsp_postdriver_hook() from every bsp possible and moved
to shared version.
