Close #3250.
Close #4081.
Update #4267.
controller support.
Update #3269.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Update #2408.
Update #2408.
Rename BSP-specific bsp_pretasking_hook() to bsp_predriver_hook().
Update #2408.
PR 1781/bsps
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, times, console/console.c, include/bsp.h,
include/cplb.h, include/tm27.h, make/custom/TLL6527M.cfg,
startup/bspstart.c, startup/linkcmds: New files.
Initial port for the TLL6527Mboard that contains blackfin 52X
range of processors. Used eZKit533 as a reference for building
the port.
