* | bsps: Rework cache manager implementation | Sebastian Huber | 2018-01-31 | 1 | -1348/+0 |
| | | | | | | | | | | | | | | | | | | The previous cache manager support used a single souce file (cache_manager.c) which included an implementation header (cache_.h). This required the use of specialized include paths to find the right header file. Change this to include a generic implementation header (cacheimpl.h) in specialized source files. Use the following directories and files: * bsps/shared/cache * bsps/@RTEMS_CPU@/shared/cache * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILY/start/cache.c Update #3285. | ||||
* | Remove excessive locking from cache operations. | Alexei Pososin | 2017-06-14 | 1 | -35/+9 |
| | | | | | | | | According to manual, the used operations (Clean Line by PA, Clean and Invalidate Line by PA, Cache Sync) are atomic and do not require locking. Update #3007. | ||||
* | Misc: Spell length correctly | Joel Sherrill | 2016-07-12 | 1 | -1/+1 |
* | bsp/arm: Report correct maximal cache line length for ARM Cortex-A + L2C-310. | Pavel Pisa | 2016-07-04 | 1 | -0/+4 |
* | bsps/arm: L2C 310 avoid infinite loops | Sebastian Huber | 2014-11-25 | 1 | -0/+8 |
* | bsps/arm: L2C 310 drop exclusive cache support | Sebastian Huber | 2014-11-20 | 1 | -71/+50 |
| | | | | Optimize locking. | ||||
* | bsps/arm: L2C 310 compile-time errata 588369 | Sebastian Huber | 2014-11-20 | 1 | -49/+19 |
* | bsps/arm: L2C 310 compile-time errata 753970 | Sebastian Huber | 2014-11-20 | 1 | -71/+43 |
* | bsps/arm: L2C 310 exclusive config is fatal | Sebastian Huber | 2014-11-20 | 1 | -7/+16 |
* | bsps/arm: L2C 310 use l2c_310_* prefix throughout | Sebastian Huber | 2014-11-20 | 1 | -99/+99 |
* | bsps/arm: L2C 310 use L2C_310_* prefix throughout | Sebastian Huber | 2014-11-20 | 1 | -232/+232 |
* | bsps/arm: L2C 310 add compile time checks | Sebastian Huber | 2014-11-20 | 1 | -81/+68 |
| | | | | Simplify initialization. Replace some assert() with fatal errors. | ||||
* | bsps/arm: L2C 310 delete invalid link | Sebastian Huber | 2014-11-20 | 1 | -2/+0 |
* | bsps/arm: L2C 310 simplify and remove white space | Sebastian Huber | 2014-11-20 | 1 | -292/+177 |
* | bsps/arm: L2C 310 rename BSP_ARM_L2CC_BASE | Sebastian Huber | 2014-11-20 | 1 | -26/+26 |
| | | | | Rename BSP_ARM_L2CC_BASE to BSP_ARM_L2C_310_BASE. | ||||
* | bsps/arm: Fix get cache size | Sebastian Huber | 2014-09-10 | 1 | -4/+6 |
* | bsps/arm: Fix invalidate instruction cache | Sebastian Huber | 2014-09-10 | 1 | -33/+2 |
| | | | | | | | Do not invalidate the entire L2 cache since it is a uniform cache in _CPU_cache_invalidate_entire_instruction(). For consitency do not touch the L2 cache even for the range function _CPU_cache_invalidate_instruction_range(). | ||||
* | bsps/arm: Change L2 cache initialization | Sebastian Huber | 2014-06-06 | 1 | -3/+1 |
| | | | | | Do not touch the L1 caches since they have been initialized by the start hooks. | ||||
* | bsp/arm: Cleanup L2 cache handling | Ralf Kirchner | 2014-04-17 | 1 | -38/+7 |
* | bsp/arm: Correct L2 cache enable method | Ralf Kirchner | 2014-04-17 | 1 | -53/+48 |
* | bsp/arm: Add cache size methods | Ralf Kirchner | 2014-04-17 | 1 | -0/+82 |
| | | | | Add new methods which deliver the cache sizes of for supported cache levels. | ||||
* | bsp/arm: Add L2 cache locking | Ralf Kirchner | 2014-04-17 | 1 | -9/+34 |
| | | | | This level 2 cache is a shared data and instruction cache and thus needs locking. | ||||
* | bsp/arm: Remove unused cache store methods | Ralf Kirchner | 2014-04-17 | 1 | -21/+0 |
* | bsp/arm: Correct cache misalignment handling | Ralf Kirchner | 2014-04-17 | 1 | -26/+54 |
| | | | | Correct misalignment handling and prepare for locking. | ||||
* | bsp/arm: Correct L2 cache flushing | Ralf Kirchner | 2014-04-17 | 1 | -17/+31 |
* | bsp/arm: Remove arm erratum 764369 from L2 cache | Ralf Kirchner | 2014-04-17 | 1 | -14/+0 |
| | | | | Arm erratum 764369 only applies to the level 1 cache. | ||||
* | bsp/arm: Add handling for level 2 L2C-310 cache controller | Ralf Kirchner | 2014-03-13 | 1 | -0/+1515 |
arm-l2c-310/cache_.h contains the handling for the L2C-310 level 2 cache controller from arm. It references the arm level 1 cache handling in the new file arm-cache-l1.h. |
