irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
wrapup/Makefile.am: Remove.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* console/Makefile.am: Misc cleanups and fixes.
* irq/Makefile.am: Misc cleanups and fixes.
* console/Makefile.am: Remove all: $(ARCH).
* irq/Makefile.am: Remove all: $(ARCH).
* startup/Makefile.am: Remove all: $(ARCH).
* wrapup/Makefile.am: Remove all: $(ARCH).
* irq/Makefile.am: Add preinstallation dirstamp support.
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* configure.in: Add include/bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of *H_FILES.
* irq/Makefile.am: Use *_HEADER instead of *H_FILES.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*
* include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES.
* include/bsp.h: Add bspopts.h.
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am:
Include compile.am.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
