Close #3250.
Close #4081.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Use value for standard U-Boot.
The baud rate of the altera cyclone-V U-Boot can not be changed at the
u-Boot console prompt. Thus we use the same baud rate as the U-Boot for
the BSP.
Implemented so far:
- nocache heap for uncached RAM
- basic timer
- level 1 cache handling for arm cache controller
in arm-cache-l1.h
- level 2 L2C-310 cache controller
- MMU
- DWMAC 1000 ethernet controller
- basic errata handling
- smp startup for second core
