path: root/c/src/configure.ac (follow)
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-1/+1
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-29/+27
| | | | * configure.ac: Remove libmisc.
* 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-071-9/+11
| | | | | * configure.ac: Append RTEMS_CPU_MODEL to ac_configure_args. Resort cache-checking.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-1/+29
| | | | * configure.ac: Expand RTEMS_CHECK_BSP_CACHE.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-0/+11
| | | | | | * configure.ac: Append CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY to ac_configure_args.
* 2002-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-141-1/+1
| | | | | * configure.ac: Use test "$RTEMS_BSP_FAMILY" != "bare" to setup HAS_LIBBSP conditional (Solaris/bash incompatibility fix).
* 2002-11-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-061-3/+10
| | | | | | | * Makefile.am: Use "'"-quotes to pass args to bsp.mak. * configure.ac: Use "'"-quotes for args to RTEMS_CONFIG_SUBDIRS. Fix braino in comment on "exec". Extend --enable-ada handling.
* 2002-08-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-281-0/+9
| | | | * configure.ac: Add ada-tests.
* 2002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-121-2/+7
| | | | | | | | Posix-BSP-Hacks: * configure.ac: Add AM_CONDITIONAL(LIBCHIP). Pass RTEMS_HOST to make/bsp.mak * Makefile.am: Pass RTEMS_HOST to make/bsp.mak. * wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+14
| | | | | * configure.ac: Add BSP_SUBDIRS. * Makefile.am: Use BSP_SUBDIRS to setup SUBDIRS.
* 2002-08-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-101-5/+5
| | | | | * configure.ac: Remove AC_CONFIG_SUBDIR(wrapup). Cosmetic cleanups.
* 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-091-18/+30
| | | | | | | | * configure.ac: Merge wrapup/configure.ac. Cosmetic cleanups. * Makefile.am: Add wrapup-SUBDIR. * wrapup/ChangeLog: Remove. * wrapup/configure.ac: Remove.
* 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-091-1/+3
| | | | | | * Makefile.am: Append BARE_CPU_MODEL tp make/@RTEMS_BSP@.cache creation (Make the bare BSP happy). * configure.ac: Ditto.
* 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-091-1/+37
| | | | | | | | | * Makefile.am: Create make/@RTEMS_BSP@.cache. Handle make/custom/*.cfgs. Create make/custom/default.cfg. * configure.ac: Add creation of make/custon/*.cfg. Create make/${RTEMS_BSP}.cache. Read make/${RTEMS_BSP}.cache
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-6/+5
| | | | | | | * acinclude.m4: Cleanups. * configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of ${srcdir}/exec/. Further adaptations to autoconf >= 2.50.
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-051-4/+9
| | | | | | | | | * acinclude.m4: New. * Makefile.am: Remove tar-installation. Prepend @exec@ to SUBDIRS. * configure.ac: Switch to AC_CONFIG_SRCDIR([optman]). Add RTEMS_ENABLE_MULTIPROCESSING. Add RTEMS_CONFIG_SUBDIR([exec]...).
* 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-251-1/+1
| | | | * configure.ac: Remove librpc.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-281-2/+0
| | | | * configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* 2002-05-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-171-1/+0
| | | | * configure.ac: Remove lib.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
* 2002-02-28 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2002-02-281-0/+1
| | | | | * DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * configure.ac: Modified to reflect addition.
* 2002-01-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-4/+2
| | | | | * configure.ac: Add AC_CONFIG_SUBDIRS(optman). Remove AC_CONFIG_COMMANDS.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-171-13/+10
| | | | | | * Makefile.am: Use SUBDIRS = @subdirs@, require automake-1.5. * configure.ac: Replace hst_subdirs with AC_CONFIG_SUBDIRS to make autoconf-2.52 happy.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+75
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
