* | bsps/amd64: add a new EFI-based variant of AMD64 BSP | Karel Gardas | 2023-04-29 | 1 | -2/+14 |
| | | | | | | | | | | The new amd64efi BSP supports: - multiboot2 boot format. Runs well with GRUB. - console based on either EFI simple text output or GOP-based framebuffer - clock based on EFI event/timer API - early console using either hard-wired PC-AT serial or just memory buffer - with EFI support disabled the BSP is more or less equivalent to amd64 BSP with multiboot2 support | ||||
* | bsps/x86_64: Add support for RTEMS interrupts | Amaan Cheval | 2018-08-13 | 1 | -0/+2 |
| | | | | Updates #2898. | ||||
* | bsps/x86_64: Add paging support with 1GiB super pages | Amaan Cheval | 2018-08-13 | 1 | -0/+2 |
* | bsp/x86_64: Minimal bootable BSP | Amaan Cheval | 2018-07-11 | 1 | -0/+32 |
Current state: - Basic context initialization and switching code. - Stubbed console (empty functions). - Mostly functional linker script (may need tweaks if we ever want to move away from the large code model (see: CPU_CFLAGS). - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for UEFI-awareness. In short, the current state with this commit lets us boot, go through the system initialization functions, and then call user application's Init task too. Updates #2898. |
