* | bsps/amd64: remove -Werror from ABI flags | Stephen Clark | 2022-08-23 | 1 | -1/+0 |
| | | | | The ABI flags for the amd64 BSP contain the -Werror=return-type flag. There is no reason for this to be there so it has been removed. The same option has also been removed amd64.cfg file. | ||||
* | bsps/x86_64: Reorganize header files and compile-options | Amaan Cheval | 2018-08-13 | 1 | -0/+3 |
| | | | | Updates #2898. | ||||
* | bsp/x86_64: Minimal bootable BSP | Amaan Cheval | 2018-07-11 | 1 | -0/+13 |
Current state: - Basic context initialization and switching code. - Stubbed console (empty functions). - Mostly functional linker script (may need tweaks if we ever want to move away from the large code model (see: CPU_CFLAGS). - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for UEFI-awareness. In short, the current state with this commit lets us boot, go through the system initialization functions, and then call user application's Init task too. Updates #2898. |
