path: root/bsps/sparc64/include/asm.h (follow)
* bsps/sparc64/include: Change license to BSD-2Joel Sherrill2022-07-121-3/+22
| | | | Updates #3053.
* Remove make preinstallChris Johns2018-01-251-0/+13
