path: root/bsps/sparc/leon2/include/tm27.h (follow)
* tm27: Avoid function pointer castsSebastian Huber2023-01-241-5/+5
| | | | | | | Add TM27_USE_VECTOR_HANDLER to select the interrupt handler type used by the <tm27.h> implementation. Close #4820.
* bsps/sparc: Change license to BSD-2 for files with Gaisler copyrightDaniel Cederman2022-11-141-3/+22
| | | | | | | | | This patch changes the license to BSD-2 for all source files where the copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research. Some files also includes copyright right statements from OAR and/or embedded Brains in addition to Gaisler. Updates #3053.
* bsps/sparc: Use rtems_interrupt_handler_install()Sebastian Huber2021-06-241-5/+19
| | | | | | | Avoid using set_vector() which depends on _ISR_Vector_table(). Prepare for a statically initialized trap table. Update #4458.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-1/+1
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+84
