path: root/bsps/sparc/include/bsp/gnatcommon.h (follow)
* bsps/sparc: Add files to Doxygen groupsFrank Kühndel2023-07-261-0/+15
| | | | Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+19
