brains GmbH.
If the bsp is integrated and supported a device tree
blob(dtb) then use dtb instead of using it from
the U-Boot (BSP_START_COPY_FDT_FROM_U_BOOT=False).
Updates #3053.
Updates #4625.
The memcpy() function may be not loaded at the time bsp_fdt_copy() is
called.
A device tree blob must be aligned on an 8-byte boundary.
The cache of the fdt blob is flushed after copy. Therefore it should be
aligned.
Update #3285.
