* | bsps/powerpc, bsps/shared: Move remaining legacy networking header files | Vijay Kumar Banerjee | 2021-06-23 | 1 | -1663/+0 |
* | bsps: Remove networking drivers | Vijay Kumar Banerjee | 2021-04-07 | 2 | -69/+0 |
| | | | | Update #3850 | ||||
* | leon,greth: added support for variable sized descriptor table sizes | Daniel Hellstrom | 2021-03-11 | 1 | -7/+15 |
| | | | | | | | | | | The descriptor table size is equal to its alignment and set when configuring the HW IP through VHDL generics. This SW patch simply probes the HW how large the RX/TX descriptor tables are and adjusts accordingly. The number of descriptors actual used are controlled by other settings (rxDescs and txDescs) controlled by the user. | ||||
* | Add networking support for griscv bsp | Jiri Gaisler | 2020-11-09 | 1 | -12/+12 |
| | | | | | | | * Only GRETH device supported for now * Fix endian problem in GRETH driver * Remove SPARC assembly from greth.c * Builds with both autoconf and waf | ||||
* | bsps: Fix warnings in greth | Sebastian Huber | 2019-05-27 | 1 | -3/+3 |
* | grlib: Move source files | Sebastian Huber | 2019-01-22 | 3 | -0/+1724 |
Update #3678. |
