* | bsps/shared/grlib: Change license to BSD-2 for files with Gaisler copyright | Daniel Cederman | 2022-11-14 | 1 | -3/+22 |
| | | | | | | | | | This patch changes the license to BSD-2 for all source files where the copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research. Some files also includes copyright right statements from OAR and/or embedded Brains in addition to Gaisler. Updates #3053. | ||||
* | grlib: Add ambapp_plb() | Sebastian Huber | 2021-06-17 | 1 | -2/+2 |
| | | | | | Replace the global variable ambapp_plb with a function to allow an automatic on demand initialization. | ||||
* | grlib: Add ambapp_common_info to derived types | Sebastian Huber | 2020-10-16 | 1 | -1/+1 |
| | | | | This avoids a cast in DEV_TO_COMMON(). | ||||
* | grlib: use rtems_interrupt_handler_install() | Jiri Gaisler | 2019-01-22 | 1 | -2/+4 |
| | | | | Update #3678. | ||||
* | grlib: Move source files | Sebastian Huber | 2019-01-22 | 1 | -0/+619 |
Update #3678. |
