* | bsps: Remove unused includes | Kinsey Moore | 2023-10-13 | 1 | -1/+0 |
* | Update company name | Sebastian Huber | 2023-05-20 | 6 | -6/+6 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | bsps/shared/*: Change license to BSD-2 | Joel Sherrill | 2022-06-15 | 5 | -15/+110 |
| | | | | Updates #3053. | ||||
* | bsps/shared: Manual file header clean up | Christian Mauderer | 2022-03-10 | 3 | -51/+34 |
| | | | | Updates #4625. | ||||
* | bsps/shared/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 5 | -18/+6 |
* | bsps/zynq: Moved general i2c files to shared directories | Stephen Clark | 2021-09-09 | 1 | -0/+482 |
| | | | | | Certain files related to the Zynq BSP's I2C driver are useable by the ZynqMP BSP as well. Moved these files to shared directory in anticipation of I2C support for ZynqMP. | ||||
* | dev/spi-memdrv: Fix use of uninit mem_param_ptr | Sebastian Huber | 2020-08-03 | 1 | -12/+9 |
* | libchip: Use rtems_blkdev_create() | Sebastian Huber | 2018-05-18 | 1 | -43/+15 |
| | | | | Update #3358. | ||||
* | bsps: Move libchip to bsps | Sebastian Huber | 2018-04-04 | 7 | -0/+2280 |
This patch is a part of the BSP source reorganization. Update #3285. |
