* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | bsps/shared/*: Change license to BSD-2 | Joel Sherrill | 2022-06-15 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | bsps/shared/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | Add _CPU_Counter_frequency() | Sebastian Huber | 2018-06-15 | 1 | -0/+20 |
Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456. |
