brains GmbH.
Update #4862.
Update #3707.
Directly call the handler on the executing processor instead of doing this
indirectly via a per-CPU job.
If CPU_DATA_CACHE_ALIGNMENT == CPU_INSTRUCTION_CACHE_ALIGNMENT we had
dead code with the previous implementation.
This fix relates to CID 1399776 (DEADCODE).
Move resposibility to disable thread dispatching to the caller of
_SMP_Multicast_action(). Using an interrupt disable for this purpose is
questionable.
Processor_mask is the internal data type to deal with processor sets.
Update #3667.
Update #3667.
Remove superfluous blank lines.
Update #3667.
Update #3622.
The following rtems_cache_*_processor_set() cache manager API functions
are exotic, complex, very hard to use correctly, not used in the RTEMS
code base, and apparently unused by applications.
Close #3622.
* bsps/shared/cache
Update #3285.
