path: root/bsps/powerpc/virtex5/include/bsp/irq.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* bsps/powerpc/virtex5: Change license to BSD-2Joel Sherrill2022-07-121-3/+22
| | | | Updates #3053.
* bsps/powerpc: Manual file header clean upChristian Mauderer2022-03-101-18/+14
| | | | Updates #4625.
* bsps/powerpc/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-2/+2
| | | | Updates #4625.
* bsps: Always build generic interrupt supportSebastian Huber2019-05-161-0/+1
| | | | | | | This makes it possible to write tests for the generic interrupt controller support. Update #3269.
* Remove make preinstallChris Johns2018-01-251-0/+82
