brains GmbH.
Updates #3053.
Updates #4625.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Remove parameters from ppc_exc_initialize() since all BSPs passed the
same values.
Update #3459.
Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt
stacks are now allocated by the linker.
Update #3459.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Update #3285.
