Move declarations of bsp_interrupt_get_affinity() and
bsp_interrupt_set_affinity() to <bsp/irq-generic.h>. Canonicalize the
<bsp/irq.h> includes.
Implement bsp_interrupt_get_affinity() and bsp_interrupt_set_affinity() only if
needed (usually RTEMS_SMP).
Provide stub implementations for i386 to fix build errors.
Add a function that allows to set the polarity (active-low / negative
edge triggered or active-high / positive edge triggered) and sense
(level or edge sensitive) of the external interrupts.
brains GmbH.
Updates #3053.
Updates #4625.
Update #3269.
Do not return a status code in bsp_interrupt_facility_initialize() since this
leads to unreachable code in bsp_interrupt_initialize(). Use RTEMS_DEBUG
assertions in bsp_interrupt_facility_initialize() if necessary.
Return a status code for bsp_interrupt_set_affinity().
Update #3269.
Return a status code for bsp_interrupt_get_affinity().
Update #3269.
Return a status code for bsp_interrupt_vector_disable().
Update #3269.
Return a status code for bsp_interrupt_vector_enable().
Update #3269.
Add a default implementation which just returns RTEMS_UNSATISFIED.
Update #3269.
Add a default implementation which clears the attributes to zero and
just returns RTEMS_SUCCESSFUL for valid parameters.
Update #3269.
Add rtems_interrupt_raise_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
valid parameters.
Update #3269.
Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Update #3706.
Pass current processor control via parameter since it may be already
available at the caller side.
Update #3285.
