path: root/bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h (follow)
* bsps/motorola_powerpc: Change defines from BSP names to avoid clashChris Johns2023-04-111-1/+1
| | | | | | - Change mvme2100 to mot_pcc_mvme2100 to avoid clashing with the RTEMS_BSP value for the BSP. You cannot have a define that is the BSP name.
* Remove make preinstallChris Johns2018-01-251-0/+233
