path: root/bsps/powerpc/gen5200/include/bsp/mpc5200.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* bsps/powerpc/gen5200: Change license to BSD-2Joel Sherrill2022-07-121-3/+22
| | | | Updates #3053.
* bsps/powerpc/gen5200: Manual file header clean upChristian Mauderer2022-03-101-21/+13
| | | | Updates #4625.
* bsps/powerpc/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-2/+2
| | | | Updates #4625.
* Remove make preinstallChris Johns2018-01-251-0/+1369
