path: root/bsps/no_cpu/no_bsp/include/bsp.h (follow)
* bsps/no_cpu/no_bsp: Change license to BSD-2Joel Sherrill2022-07-121-3/+22
| | | | Updates #3053.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-0/+16
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+41
