path: root/bsps/nios2/nios2_iss/include (follow)
* bsps/nios2/nios2_iss: Change license to BSD-2Joel Sherrill2022-07-121-3/+22
| | | | Updates #3053.
* bsps: Always build generic interrupt supportSebastian Huber2019-05-161-0/+1
| | | | | | | This makes it possible to write tests for the generic interrupt controller support. Update #3269.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-0/+20
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-252-0/+131
