Update #3707.
Sort the .noinit* input sections by name first, then by alignment if two
sections have the same name. This allows the placement of begin/end symbols to
initialize some areas with a special value.
Update #4678.
Updates #3053.
Updates #3937.
Close #3250.
Close #4081.
Update #3866.
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Update #3838.
Update #3269.
controller support.
Update #3269.
Update #3706.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
replace.
searching and sorting.
Update #3706.
Update #3459.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
